A little update on my adventures with my MD6A that has not been preforming properly..brbr
Yesterday (Saturday), I installed the rebuilt fuel injectors and took the boat out for a test drive. While the boat does preform better, it still seems there is something wrong.brbr
I can go about 2 times faster (my knott meter is not functioning) with the new injectors, but several of the symptoms have not changed.brbr
1. At about 1/2 throttle and above, I get the black exhaust smoke and no increase in RPMs or boat speed.brbr
2. The sound of the engine has not changed much that I can tell. I was told by a diesel mechanic that the engine didn't sound right and that I was only running on one cylinder. I was expecting to hear twice as many popping sounds per second if the second cylinder was firing.brbr
When the injectors were out, I did crank the flywheel and did see fuel squirt sequentially out of the fuel pump. Also, the fuel filters were either changed or cleaned and the electric fuel pump was changed out.
thanks,
groundhogbrbr_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
thanks,
