Jim
Hi all, Hope everyone out there is set for a great 4th of July. Just ran into some starting problems with my 16 HP Atomic Universal Diesel. Basically seems like a toss- up between the Starter being in trouble or, more likely, the Alternator not delivering a charge to the batteries. After a few outings where, unless the motor was already warm from a previous power-up, starts were getting to be more difficult, with seemingly not enough oomph in the crank...like one slow turn of the engine instead of the usual multiple turns. I recently had to use a power pack back-up to get the engine going so we could get back to the dock. After a 15 minute run back to the dock and, on the following day, a cleaning and reseating of all the terminals on the batteries (one house/starter and one deep cycle), I was unable to start the engine. All I got was a one, rluctant turn of the engine and nothing else. Then, after charging the batteries for a while with my onboard charger, she turned right over, virtually instantly. So, although we'll need a few more easy starts like that to make the case, I think we're heading toward ruling out the Starter as the source of the problem, even though it is possible that we just got over a dead spot and such. Now then, despite my ammeter always reading on the plus side while the engine has been running, supposedly indicating the alternator is charging the batteries, and having spent last weekend motoring for about 7 hours, which should have provided more than enough charging time for any depletion of charge on the batteries until then, it seems like the alternator may not be adequately charging the batteries. And, it may be that this has been the case for quite a while, as starts have been a little tougher to come by during the last month or so, despite the weather here having warmed up quite a bit of late. I also should note that the voltmeter readings on each of my batteries have consistantly been more than adequate throughout the last month's activities, including the other day when we had to add the back-up power pack to get going and back to the dock. My experience with batteries and alternators, and the guages and systems provided to supposedly warn you of trouble, particularly on cars, and now I guess on boats also, is that they are all largely useless. I have gone through several failed alternators and/or batteries in my day and never, ever gotten an idiot light or an ammeter reading which warned of a failing battery or the failure of an alternator. This is a mystery I believe only the engineers of the world could begin to fathom, but that's another story...
Anyhow, my real question is, if we have a fully charged pair of batteries which are in good shape, and the alternator is failing, shouldn't we nevertheless be able to get out there and get quite a number of good, easy starts with the diesel before the batteries drain again? Just looking to get this 4th of July weekend of sailing in, probably 5 or 6 starts in 85 degree+ weather, before going after this problem in force and fixing it. As I understand it, diesels only consume electricity with the use of their glow plug and for engaging the starter. So, if my recent experience is any indicator, it seems we should be able to get in quite a number of starts before we fail again. As well, we've also got the power pack back-up and, as a last resort, towing insurance...
As well, we're talking Long Island Sound, with only the possibility of an isolated thunder shower in the forecast right now so, while I far prefer all systems up and running well when we go out, I don't think we are talking much risk here at all. However, your comments and thoughts are welcome as always, on both the starting problem itself and our weekend plan to temporatily beat it...Fair Winds, Jim
