L
Lee
I have two starting batteries(flooded) and I would like to replace one with a Deep Cycle house battery for cruising. I have the factory 1,2 or both switch and since my charger only has one line coming out, it is connected to the switch's 1 post and the only way to charge the #2 battery is by placing the switch to both. I don't know if this problem also exists with the engine alternator since I do most of my charging by A/C.(The engine will start on either 1 or 2 alone or both).My question is, can I replace one of the batteries with a deep cycle or will there be a problem when I place the switch on both for charging? I guess one will bleed into the other until they equalize when the A/C is off and the switch is on both. Will I be able to still operate on both when needed with different batteries?(Not different type but different designation, ie starting/deep cycle). Thanks. Lee
