I went to take my still-new-to-me Seafarer 29 "Blue Moon" out the other day and the ignition failed to react at all, dead as a doornail. Batteries were fine. I tried to trace the wiring but wasn't able to find the fault on my own. So I had the marina fix it for me, it was a broken wire that must have happened when I was rummaging around in the locker.
Next time out I ran the engine, a single-cylinder Yanmar, flat out for quite a while, having read somewhere (on this forum, I think) that diesels like to run at full throttle and behave better if you do that. Found that the 8hp engine will push her at 5.6 kts running full throttle in calm water.
So anyway, now there's a new problem. The starter whirs when I turn the key but doesn't crank the engine. Before when I turned the key, it would go chugga-chugga-chugga until it caught and started to run. Then Saturday it went chugga-chugga-whir but on next try it started. After sailing a bit (and dropping my almost new phone in the lake) it started right up again.
Now it just goes whir, no chugga-chugga.
Could it be the solenoid failing to engage the starter with the engine? (That's just an uneducated guess.)
