Can anyone enlighten me on the actual wiring for a new "pre-engaged" starter on my new Yanmar 3YM30. The wiring diagram in the manual is as I would expect, battery to the 'B' post and start wire to the 'E' post. But the new starters do not have those posts. Instead it appears that all the wires((battery switch(hot 12v), panel wire, and factory bundle(incl. start wire and alternator?)) go to the same post. Following is some dialog from the UK Yanmar help site:"it's a standard style pre-engaged starter motor with three solenoid connections. The main + is just the power supply to the starter. There is a separate thin white wire which is the switching wire to energise the solenoid (via the key switch & start relay) and a third terminal which takes the power from the solenoid to the motor itself. The operation is described here: http://www.powerbase-auto.co.uk/starter_motors.htm "Well there may be a "thin white wire" somewhere but it is encased in the factory bundle. On my old 2QM20 it was the old way. All 12 volts supplies and sources were taken off a common solenoid post. Then there was a separate white wire from the pushbutton/key switch to a separate solenoid post to energize. Any ideas are welcome.
