on my YSm12 it took longer to pull the cabinet for access then it did to replace the starter. The main problem is the bill for the part was about $450. If I had to do over, I would search the tractor stores for a replacement part.
As per Bill's above post- If you don't bleed on a job, you are not working on your boat.
