Tim
I have an 88 Cat 30 tall rig with a Universal M-25 XP. I rcently had a starter problem where I hit the start button and the motor turned over, but when I released the start button the starter did not disengage. I had o kill the disconnect switch to shut the motor down. I replace the solenoid valve but am still experiencing the same problem. I have jumped the solenoid (bypassed the start button with a screw driver) and still the same problem. I've even connect the solenoid to power but not to the starter to check the throw and release of the solenoid and it appears to be fine.My questions are #1 does anyone know of another area to check before I replace a $530.00 starter?#2 Is the starter replacement better left to a mechanic or is it something anyone could handle?
