Starter on Hunter 29.5
Elie
Dec 15, 2015
26
Hunter 29.5 Marina Del Rey
has anyone replaced the starter on their 2gm20f motor?
my motor won't start and the mechanic told me I need a new starter. I see the yanmar ones are about $400 and there are a bunch of aftermarket ones for around $100. anyway have any experience with these? the other option is rebuilding, which my mechanic doesn't want to deal with.
Jan 4, 2006
7,870
There should be a number of automotive electrical shops in your neighbourhood which can give you a much better idea of whether to repair or renew.
May 24, 2004
7,235
CC 30 South Florida
I would take it to an electric shop but instead of asking for a rebuild I would ask for a repair. Some components like brushes and bearings are easily replaced. Others like the field or the armature are more intricate and I would prefer to save the OEM parts if possible. The electric shop will likely use aftermarket parts so it is best to try to save as many as the original parts as possible. you could save some money too.
Nov 6, 2006
10,256
I wonder if the guy eliminated the usual bad connection starter problem before declaring that the starter was shot. Usually a non start on a 2GM Yanmar is a bad set of connections in the push connectors of the wiring harness.. Not saying that the starters don't fail..
Oct 29, 2005
2,366
Yup! As what Kloudie said. Could be plugs and terminations at the starter. This happened to me just 2 weeks back. Start engine, no turn but heard only solenoid click. Check the usually connectors, not it. Suspect starter faulty. Then unscrew and retighten the big wire terminations at starter and voila! Engine can start.
Oct 29, 2005
2,366
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
I am 3 years into a $89.00 starter from ebay. Exact fit and only took about 15 minutes swap it out. To rebuild the old one was more than the price of the ebay model.
