Echo Charger Purpose
quadrille38 - Thanks for checking with your dealer - mine went bankrupt but was never any help re service questions anyway. You are lucky
Stu - fully agree - I looked at the wiring schematics and the actual wiring of my panel and checked how it all operates with a multimeter last weekend.
On my unit, the solenoid connecting the parallel start / charge breakers is open when the ignition key is off and closed when the key is on. When the engine is running, the alternator charges the starter battery directly always regardless of the breaker position. When both switches are on and the ignition key is on, the house and starter batteries and starter are connected for starting. When both switches are on and the engine is running, both the start and house batteries are being charged by the alternator with the same voltage. If the house switch is off, the house battery does not see the alternator when the engine is running.
When docked with shore power and the engine off, my AC powered battery charger (Protech1230i) charges the House and Starter Batteries with two separate circuits. I called ProTech and they say the charger is designed to handle different bank sizes separately as long as they are the same battery type - AGM in my case.
I would like to know what is the purpose of the Echo Charger? The Echo Charger manual that came with the boat shows it is for charging the start battery when the shore power battery charger is wired to only charge the house. I think it may be set up on the Hunter to charge the house battery when the start battery is being charged by the alternator. If Racine knows his answer would be welcomed. This why I am trying to locate the Echo Charger.
