STARboard Edson Top Plate
Rovic
Oct 25, 2006
39
- - Riverport, Nova Scotia
Spring project; install a NavPod CP20RA & AG225 on a H37c which has the original Edson pedestal guard. The Edson is 9.5" on center with a 1" tube ( I'm guessing here as the boat is in Annapolis & I'm in Nova Scotia ) The system I wish to install is 12" center & 1.25" tube. The problem is that there doesn't seem to be a Top Plate Adaptor to fit the Edson for a 12" x 1.25". I found one for 9.5" x 1.25" (TP125). So, can STARboard be used to fashion a Top Plate for the 12" size and will in be strong enough. Also is there enough room when replacing the original Top Plate with one made from 1/2" STARboard between the top of the Pedestal and the Compass.
May 27, 2004
5
Catalina 30 San Francisco
try calling Edson
You might want to try talking with Edson. They probably carry parts to support your project. 508 995 9711 or their web site www.edsonmarine.com
G
Greg W
Top Plate
Ocean Marine has a top plate for the 12" wide 1.25" tube. I just received one last week as I will be also attempting to install a new 12" wide 1.25" diameter pedestal guard in the spring. The part number is TP225 894001217 and it is white. Ocean equipment can be reached at 949-588-1470. Stay in touch as I would be curious as to how your installation goes especially if you are going to do it prior to April. Thanks, Greg Weisheipl De Pere, WI.
Rovic
Oct 25, 2006
39
TP225 Makes Sense
Thanks Greg, AG225 = TP225. I found the TP125 but didn't think to search TP225 although I looked through all the categories. I must have been tired, it was a long Xmas. I think you will be ahead of me on the new install, I don't think that will be off the list until May, it's a long list. Is your pedestal a Edson.?? Robert
Dec 25, 2000
6,065
Hi Robert, Edson also makes a white marine-
grade polymer top adapter for their #335 and 336 pedestal. The order number is 694WH-45. You can e-mail them at info@edsonintl.com according to their catalog. Terry
Dec 17, 2006
27
- - De Pere, WI
Top Plate Special Order
Robert: The TP225 is a special order from Ocean Marine and likely will not be found in a catalog or on a web site. Greg W.
Rovic
Oct 25, 2006
39
Edson Pedestal or different
Greg Was your pedestal a Edson or another brand. Robert
