6mm seems overkill, increasing the cost of the wire and all related fittings and adding extra weight to the rig. If you want extra strength in a 5mm wire check out DYFORM, aka Compacted Wire.There is also the Synthetic Rope option.I've used Hayn Marines Hi Mod compression fittings on two different forestays and will use them again. They have a special crown ring that is re-usable, rather than needing to replace the crushable wedge as in Sta-Lok fittings. I know that swageless fittings are costly, but they give you the option of making your own repairs or replacement as needed, without the need for special tools. You could carry a length of synthetic rope for use as an emergency stay. It's very strong and does not stretch. I use it for my lifelines.Petermostlyaboutboats.ca
