Indeed, Selden Spars ran some tests in the 90s (I think) to find out
how important the question of point loading is (which occurs when you
have a mismatch in pin/hole size). They discovered that with static
loads you can expect a 5% decrease in strength for every 7% increase
in hole size above the ideal.
So, to take Larry's example of 3/8" holes with 5/16" pins, the 20%
difference in size would weaken the rig by almost 15%. In real terms
this is comparable to cutting 2 to 3 yarns out of a shroud; a scenario
that would have each of us replacing the wire in a hurry.
If you drill out the fittings at the masthead to take a bigger pin,
and avoid point-loading, then you need to check that you have at least
the diameter of the pin in spare metal all the way around the hole so
as not to weaken the fitting. As Larry points out, there isn't enough
stainless to allow for drilling, and so you need to change out the
tangs.
Albin really did know what they were doing; it is important to
understand that the rig is a 'system' and, although not complicated,
it really isn't as simple as just upgrading the thickness of the wire.
Don't even get me started on those that add a babystay without adding
running backstays
Fairwinds and pleasant sailing,
Adam
