Michael
I have recently aquired a 1974 Paceship PY23 that one of the stanchion was forcibly removed. The base-plate is missing. All I have is the pole.Obviously I need to replace the plate but my main concern is how to properly fasten it to the deck. The hole left by the accident is about 3" in diameter and appears to have some softer material inside. I was thinking of filling it with epoxy and using a back-board inside the cabin to run new bolts through, but the cabin ceiling isn't the same fibre-glass as the deck. Apparently there's something in between the 2.Any advice would be most welcome.
