Stanchion grommets
G
Gary Bridi
I have a 1992 H23, but this probably applies to other models. There are black plastic grommets in the holes in the stanchions through which the lifelines. Any idea where I can get replacements? thanks
Mike Epp
use plastic tubing
I figgered since the old ones popped out......so would new ones. I just got some plastic tubing and cut it to about 1inch lengths, then cut it longitudinally and placed around the lifelines and pushed into the stanchion holes. Works fine.
K
Ken Palmer
Try your local harware store
I have the same problem replacing them on my H33. While in the hardware store last week, I noticed a bin in the hardware section called "nylon snap bushings". These look like the exact replacements (except my old ones are white). Measure the diameter of the hole you are filling, and buy a few for fit. They sell for about 25 cents each I believe. Be aware that the stores don't seem to stock in high quantities, so don't wait too long before buying them if you are replacing all. Ken Palmer, S/V Liberty
