Stanchion Base Data
3
Hunter 40 Marco Island, FL
Looking for stanchion base, 1985 Hunter 40...understand many other Hunter models use the same stanchion base. Any and all help appreciated...this seems to be a proprietary design, not found through usual marine channels.
Johnb
Hunter 37-cutter Richmond CA
This does not truly answer your question but I have found it cost effective to have stanchions repaired. It comes out to be about 1/2 the price of new and you could not see where the fixes were. 10 years of salt water sailing and there are no corrosion problems, and re installing was a snap. For one folded over stanchion and one broken off I was charged 30 minutes labor each, including polishing to perfection.
Mar 15, 2004
3
Thanks much for the response. My stanchions, however, are fine...I merely require BASES.
