Had to replace Hurth Trans on my 1985 - 27' Catalina due to salt water getting in. Discovered that shaft was worn and took mechanics rec to replace it. The new trans is 1 inch longer than the old one and I was going to have the existing shaft cut down by one inch - then found out about how worn the shaft is.New shaft will be stainless - old one was bronze, as is the prop. I intend to use the existing coupler and will have it refaced so as to be squared with the new shaft. Do I have a problem with having two different metals?
