If you dont find a loose connection, the call Raymarine support and get the 'output voltages' and resistances-Ω for the mast unit ... a go/no-go method to test the mast head without mast climbing. Such values 'may' be in your manual.
If your wind machine is connected to a 'seatalk' network ... check every damn connection in the entire network and especially at autopilot interfaces, etc. Be sure to check the fuses on the course computer for the autopilot if so integrated.
Lightning is not a windmachine's friend .... including lightning from 'thunder snow'.
