st60 wind, masthead schemetic?
449
Catalina 400 mkII Harbor
i am getting ready to drop the stick on tuesday and change the wind vane to raymarine. my current vane has 4 wires, the raymarine has 5 wires. does anyone know if i could use a ground for one of the wires in the event i cant pull the new wire through the compression post area? i will try to pull the new wire but if i cant i would pick up a ground from one of the lights. i only want to have the mast down for a day if it can be helped! ps 1984 hunter 34 regards, mike
Jun 4, 2004
629
Sailboat - 48N x 89W
Raymarine Owners' Manuals
The "screen" wire is grounded, so might be substituted with a lighting ground - tho' definately NOT recommended. Goto Raymarine (http://www.raymarine.com/raymarine/), click on Customer Support: http://www.raymarine.com/raymarine/default.asp?site=1&section=3 Click on Owners' Manuals, then ST60, then Wind @ http://www.raymarine.com/raymarine/SubmittedFiles/Handbooks/Instruments/ST60/81105_4www.pdf HTH, Gord May
