ST60 + Speed /Temp sensor
30
Beneteau 43 Milford, CT
I have a Airmar speed temp sensor hooked into my ST60+ system. The temp is at 104 all the time and the speed works fine. From all I have read it sounds like the sensor must be replaced. Does anyone have the replacement part number for this item? Is it repairable?
Mar 6, 2008
1,524
On my last boat the temperature sensor was embedded in the same transducer as the knot meter. I do not believe you can replace or repair it. You may have to replace the the knot meter. Call Airmar. You may also consider removing it and placing the transducer in an icewater to see if it will display a different temperature.
