ST50 or ST60 wind sensor parts
1,637
I believe the units are made by airmar.
Rotating cups etc are spares from Raymarine.
If you need the ball races here is what they are - cut and pasted from my boat file.
Raymarine Masthead Unit
The bearing code is DD 830 ZZ which means OD 8mm, ID 3mm, width 4mm and ZZ means non-contacting shield. Two bearings from NMB in Japan.
I got mine from a normal engineering bearing supplier.
