Hi Siep -This happens to me rather often. For my setup the cause is a loose plug feeding into my chart plotter. I assume the plug is coming from the fluxgate compass. pull and carefully re-plug all the inputs into your plotter to see if this solves the problem. You should also make sure the contacts are clean.good luck
