st4000 autohelm pin size
david
Does anyone know the pin diameter and length that is used an anti-rotational feature in the st4000 autohelm wheel drive unit. This is the pin that fits into the motor housing and is number 26 in the exploded view of the service manual. Thanks
Apr 26, 2005
286
Beneteau Oceanis 390 Tsehum Harbour, BC, Canada
ST4000 Lever Pin
David, I just had the pin that holds the black lever to the back of the circular wheel drive unit replaced. What a pain! Those parts are expensive!!! The service guy was incompetant and bent up about three pins before he could get it in properly to hold the lever on. He had to take the whole unit back to his workshop and install it using his vice. Autohelm have designed that whole system to make them bags of cash in replaced parts. Can't help you though but commiserate.
