If you own a Raymarine ST4000+ autohelm you are likely aware they no longer provide replacement drive belts. While my original belt was still functioning I thought I'd see if I can locate a suitable replacement before it failed. The results of my search might be useful to others.Here is what I learned about synchronous (toothed, timing belts).The original belt was labeled “Synchroflex AT 5/750”. Some time on the web and discussions with local suppliers decoded it as a 750mm long (circumference), 5mm pitch synchronous timing belt. The “AT” apparently means “American Trapezoid” which describes the tooth shape. The only thing missing is the width which doesn't appear in the label but was measured at 9mm.A search of major belt suppliers was close but no exact match was found. Gates has belts identified as T5-750-10 which describes a trapezoid toothed (not “American Trapezoid”) belt of the correct pitch and circumference but 10mm width. They also have a 8mm belt. Note: some manufactures specify number of teeth instead of circumference/length. 750mm/5mm=150 teeth.A local supplier was able to locate a 5/750/9mm belt from Ametric. There was no reference to tooth profile. The Ametric part number is 5.750.9. I ordered ($31 + shipping) one and installed it today. The pitch/width/circumference is correct however the tooth profile is slightly different. I didn't have time to take the boat out for a test spin but tests at dock were positive.Taking the boat out for a week downriver in a few days so will find out if it is a suitable replacement.Hopefully useful information to ST4000+ owners. If anybody has found an exact replacement please let us know.Regards,JeffC30 MkIII,TRBS, 6431
