Worked perfectly at beginning of season but wind direction is now off 30 degrees. Wind speed is working correctly. I have checked connections except at top of most. Tried linearisation and this is what happens. Two circles at 3nm, 2 minutes each. Shortly after starting the turns the screen goes to ADJ, but I never hear the audible sound that linearisation is complete. All the time I am making the circles the direction erratically changes. I then go into the wind and adjust to 0 degrees, but this does not correct the problem. What might be the solution to this problem? I tried the Raymarine forum but my post was not accepted even though I was granted permission to post. Certainly not very oonsumer friendly. Joan
