St. Horizon 2150 vhs/AIS to C95
galynd
Nov 1, 2009
170
Beneteau 36cc port arthur, tx
I'm trying to connect my stand horizon vhf/ais to my raymarine c95 chartplotter to show ais data on the chartplotter. This might be asking a lot but can anyone give me the schematic, specifically color coded. I believe there is about 5 wires that must connnect.
thx.
greg
Tim R.
May 27, 2004
3,626
I can probably figure it out if you post the two devices wiring diagrams including color codes.
Feb 6, 1998
11,760
This is what I have in my notes:
Set VHF baud rate to 38400 set Raymarine port 1 to high speed baud of 38400
VHF PLOTTER
Gray = White/IN +ve
Green = Green/IN -ve (jumpered with Brown/OUT -ve Ray end)
Blue = Yellow/OUT +VE
Brown = Not used
galynd
Nov 1, 2009
170
Thanks Gentlemen. This is the wiring info from both manuals:
Directions from VHF Standard Horizon 2150:
Matrix AIS+4800 Baud Connections
Use the image and table below when connecting to a gps Chart Plotter which has two or more NMEA 0813 ComPorts.
Radio Wires Plotter Connection
Gray:NMEA output (+) NMEA IN (+)
Blue: NMEA input (+) NMEA out (+)
Green: NMEA common (+) NMEA Common (-)
Brown: NMEA Output (+) NMEA – HS IN (+)
Note: HS = 38400 baud
White – External Speaker (+) Positive wire of a 4 Ohm External Speaker
Shield – External Speaker (-) Neg wire of a 4 Ohm external Speaker
Red – PA Speaker (+) Positive wire of a 4 Ohm PA Speaker (horn)
Shield – PA Speaker (-) Negative wire of a 4 Ohm PA speaker (horn)
Green- NMEA Ground GPS chart Plotter NMEA 0183 common
Blue – NMEA GPS input (+) GPS Chart Plotter NMEA 0183 output positive wire *1
Gray- NMEA DSC Output (+) GOS Chart Plotter NMEA 0183 input positive wire *1
Brown – AIS DATA Output (+) GPS Chart Plotter NMEA input positive wire *2
*1: 4800 baud
*2: 38400 baud
Information from raymarine c95 chartplotter:
Item Cable color port Input/output +/-
1 white 1 Input Pos
2 Green 1 Input neg
3 Yellow 1 output pos
4 brown 1 output neg
5 orange/white 2 input pos
6 orange/green 2 input neg
