OK here's the story.
I was working on the boat listening to the radio with the vhf on and no other electrics on. I put in new house batteries 2 wks ago and they were fully charged before installed.
I finished up early and decided to go out for a couple of hours. Since I was going alone I was planning on using the auto-pilot to make my life easier.
I motored out on to the lake about a 10 min run on the motor.
I turned on the a/p and was going about the boat getting things set up and check on everything since this was the first trip out of the year.
The a/p was working great for about 10 mins. the it started to beep. I went back to check on it and the LOW Battery alarm was going off. Then the a/p went into standby mode.
So now here's my question. Would the a/p run the 2 house batteries down that quickly? Or after running for that amount of time would the wiring warm up and cause more resitance and cause the voltage drop. Or?
I don't have a battery monitor and I didn't get down to check the battery voltage with my meter. To busy single-handing woth out the a/p. Even after starting the motor and trying the a/p again it still showed low battery and would go into stby.
I did see on the archives that these a/p draw about 4 amps when engaged. I don't think it's the batteries since they are new. But it could be them.
Any help would be great
thanks again
Don
thanks again
Don
