Hi - on the boat I recently bought there is a Target HF3/W-HF3/P existing receiver. The backstay has a long insulated portion but the connection from the backstay to the receiver is missing. Would appreciate some input from more experienced users <G>
Note: currently plan to operate in receive mode, may purchase a transceiver later next year.
I plan to use a bulldog clamp to attach some Ancor GTO-15 to the insulated portion of the backstay, install an MFJ-722 lightning arrestor, and then run that to the receiver with RG58
1) all of the wiring setups I have seen on line have a tuner installed between the GTO-15 and the lightning arrestor; but the tuner I believe is only required when you are transmitting - which with the current setup I wont be - can I connect the GTO-15 directly to the MFJ-722? (there is no braid to connect??, just the center connector??) - the receiver I have has no control cable to control a tuner
2) Do I need to install a ground plane such as the KISS radial ground?? If so, what do I connect the ground to at the antenna side ?
Those are the questions I know about, if there are others I should be asking please let me know !!
My plan is to get the receiver working (my boat is in the Philippines), and see what sorts of SSB is available and active there before making the jump and installing a full blown SSB system on the boat
Advice welcome !
thx
Rick
Advice welcome !
thx
Rick
