4" foil best...
Brian, Vic's got it right about surface conduction. Defender offered the best price on 4" copper foil last time I looked, altho' some folks like to cut copper flashing from the local Home Depot (use gloves!).It sounds like you're stuck with a molded liner that's preventing access from one cabin to the next. The foil should be run below the waterline and adjacent to hull (capacitive linking) so running it against a liner that isn't butted up against the hull isn't optimum. There's nothing to say you can't cut a slot in the bulkhead between cabins (if access permits that) and there's nothing that says a foil run back & forth, several times, in one cabin but below the waterline, is any less effective than a run of the same length that keeps going in one direction. Your looking for max surface area linked to the water.The best advice I've heard on all this is to start by doing what's recommended but only to the extent that it's relatively easy to comply with. Then see what results you get. (You do have a SWR Meter, right?) If you have a poor SWR then more effort is required; if not, whoopee!Jack
