SSB Antenna
27
1984 Hunter 31 Geneva Ohio
I am Setting up my 84 hunter 31 for cruising and am installing a SSB Radio. I am looking for recomenations on an antenna for the boat. I have a split backstay and can insulate it but I am looking for other alternatives that others have used.
Sep 9, 2005
61
- - St Joseph, MI
You will want to research to determine the minimum desirable length of your antenna. Any I've seen have appeared to have been longer than the upper or lower portions of a backstay on a boat of your size. You may be able to use one of the lower side stays or have to use an upper. If you can use the back stay, that will be preferable as it will be easier to route the cable through the stern railings into the cabin than having to drill through at a mid ship location.
Rick D
Jun 14, 2008
7,187
What Many In SoCal Now Use
Most of the more recently rigged boats in SoCal i've seen have gone to a whip antenna. See link for one example.. RD
K
Karl
Gam Electronics
There is also a new SSB antenna out on the market. I don't know anyone that has used it yet, but Gordon West has endorsed it and he is the guru on radios. The antenna is made by Gam Electronics and it basically snaps on to your backstay. Nice thing about it is that there is no need to cut your backstay.
7,497
Alden 50 Sarasota, Florida
whip antenna advantages
in addition to it being alot easier to install compared with backstay modifications, it is independent of the rigging should anything catastrophic happen when you are cruising
