In another thread there's a discussion going about wire sizes in the mast. I have a question about lighting on the mast.My Cal 28 currently uses a combination anchor/steaming light at the mast truck. I would like to really get some light on the deck for those occasions when you just plain need to see on deck at night. Having seen genny leeches ripped up by things on the mast, I'm sort of concerned about the steaming/deck light combo. However, I wonder about windage and other problems with spreader lights (and I guess the genny going past on a tack could get hung up on these as well). Don't spreader lights add problems to unstepping/storing the mast. The spreaders are usually removed for storage at my yard and it seems like having lights/wiring on them would complicate that. If I use spreader lights, do I need connectors at the mast?So, what works best all around, steaming/deck light on leading edge of mast, spreader lights on the lower spreader, both, or none of the above? If one or both of these is appropriate, does anyone have a suggestion as to what light(s) work best and are still reasoably efficient?-Smitty
