Bill Heaphy
Have fresh water cooled A-4 on our Cat-30. At low/idle rpm get a squealing noise like a loose fan belt. Tightened and lubed both belts; no help. Noise is intermittant. Could this be the impellar in fresh water side pump rubbing on housing cover? Seems I heard about this some time ago and fix was to install two cover gaskets for better clearance. Anyone had this problem with their A-4? Thanks for your help.
