Witzend – in 2011 you posted a thread re squeaks from the engine/alternator belt/pump/s. Did you ever find the cause of the problem? Seem to be hearing similar noise: intermittent almost metallic chirping that seems to disappear when engine has run a while. Alternator runs freely without belt, but freshwater pump seems to be sticking/chafing inside a bit. Don’t want to take the raw water pump apart as yet, as I am trying to obtain all my maintenance parts direct from the US in one order if possible, to save freight,which seems to have increased quite a bit lately. I replaced it (Sherwood) 12 mths ago.
I did tighten the belt a few weeks ago, but had no problems until now.
Any info would be appreciated.
