Spring Pre-launch
The checklist is also available at http://www.BoatUS.com/freebies.BEFORE YOU LAUNCH:__ Inspect and lubricate seacocks. Hoses and hose clamps should be inspected and replaced as necessary.__ Replace deteriorated zincs.__ Inspect prop(s) for dings, pitting and distortion. Make sure cotter pins are secure. Grip the prop and try moving the shaft – if it’s loose, the cutlass bearing may need to be replaced.__ Check to make sure the rudderstock hasn’t been bent. __ Inspect the hull for blisters, distortions and stress cracks.__ Make sure your engine intake sea strainer is free of corrosion and properly secured.__ Check the engine shaft and rudder stuffing boxes for looseness. After the boat is launched, be sure to check these as well as through-hulls for leaks.__ Use a hose to check for deck leaks at ports and hatches. Renew caulk or gaskets as necessary.__ If equipped, ensure that stern drain plug is installed.OUTDRIVES and OUTBOARD ENGINES:__ Inspect rubber outdrive bellows for cracked, dried and/or deteriorated spots (look especially in the folds), and replace if suspect.__ Check power steering and power trim oil levels. Replace worn-out zincs.__ Inspect outer jacket of control cables. Cracks or swelling indicate corrosion and mean that the cable has to be replaced.ENGINES AND FUEL SYSTEMS:__ Inspect fuel lines, including fill and vent hoses, for softness, brittleness or cracking. Check all joints for leaks and make sure all lines are well supported with non-combustible clips or straps with smooth edges.__ Inspect fuel tanks, fuel pumps and filters for leaks. Clamps should be snug and free of rust. Clean fuel filters.__ Inspect cooling hoses and fittings for stiffness, rot, leaks and/or cracking. Make sure they fit snugly and are double-clamped.__ Every few years, remove and inspect exhaust manifold for corrosion.__ Clean and tighten electrical connections, especially both ends of battery cables. Wire-brush battery terminals and fill cells with distilled water.__ Inspect bilge blower hose for leaks.SAILBOAT RIGGING:__ Inspect fittings for cracks and rust. Inspect wire halyards and running backstays for “fishhooks” and rust.__ Remove tape on turnbuckles and lubricate threads, preferably with Teflon. Replace old tape with fresh tape.__ Recaulk through-deck chainplates as necessary (generally, once a decade).TRAILERS:__ Inspect tire treads and sidewalls for cracks or lack of tread and replace as necessary. Check air pressure. Don’t forget the spare!__ Inspect bearings and repack as necessary.__ Test tail and back-up lights. Test winch to make sure it’s working properly.__ Inspect trailer frame for rust. Sand and paint to prevent further deterioration.MISCELLANEOUS:__ Check expiration dates on flares and fire extinguishers.__ Check stove and remote tanks for loose fittings and leaking hoses.__ Inspect bilge pump and float switch to make sure it’s working properly. __ Inspect dock and anchor lines for chafing.__ Update or replace old charts, waterway guides.__ Check shore power cable connections for burns, which indicates the cable needs to be replaced.__ Make sure your boating license and/or registration is up to date. Don’t forget your trailer tags.__ Review your boat insurance policy and update coverage if needed. Be sure you have fuel spill insurance coverage.__ Make sure you have a properly sized and wearable life jackets in good condition for each passenger, including kids and pets.
