Do you work off a list? every year I seem to foget one item,last year I forgot to open the sea cock when I first started it and yesterday I forgot to check the engine shut off so there I was in the travel lift slip and crankin and crankin old red (Westerbeke 30)thinking to myself whats wrong with this engine *o cause she always starts and finally started but was running on 2 cyl. thats when I checked the shutoff cable and it was halfway out. (I always reset this so the engine is in the ready to start position)I check the engine from memory before and after startup:Charge the batterybattery connectionsantifreezeoiloil leaks (engine gets wiped clean in fall)beltssea strainerhose'strans fluid shaft flange couplingstuffing boxwater exiting the exhaust
