H
Herb
What is on the end of a spreader that holds the shroud, or what is on the shroud that attaches to the spreader? Mine just came loose and I now have an aluminum spreader with a molded plastic end that has a notch for the shroud. The shroud has a white rubber boot that holds whatever attaches to the spreader. Everything is up in the air and I would like to know how it all goes together before I find a way to get up to the spreader to fix it. What is it and where do I get a replacement part if needed? O'day 26Thanks, Herb
