Spreader tip Hunter 310
Nov 28, 2026
2
Hunter 310 TSS
I’m helping a guy with his hunter 310. He broke upper shroud, I think it’s term D2. The rigging is not arranged as in the diagram in the manual. Both the lower and the diagonal in addition to the upper terminate on a single 3/8 inch pin. The inner 5/16 inch hole is empty. Is there any benefit to this particular arrangement or should the diagonal be in the 516 inch hole?
I think I would rig it the way it was designed.
I assume the RD1 is meant to be retained with the 5/16th spreader tip pin. But it's not clear to me from the diagram.
  • Helpful
2
Hunter 310 TSS
The diagram shows RD1 thru the 5/16" pin. Although, now that I have thought about it for a day, that eye is 3/8" so isn't a good fit for the (absent) 5/16" pin. I will probably just reassemble as it was which will avoid creating new issues or the need to figure out how to retune the rig.
