How does anyone connect their upper shrouds to the spreaders on a Hunter 23? I just use string similar to shoestring and run it around the shroud outboard of the spreader and back through the two holes (one each side of the shroud) on the spreader. Just to keep them in place when lowering and raising the mast, and if they go slack on the down wind side should I not have enough tension. Can't wait for spring. thanks, John
