Spreader poles
133
- - Plymouth
I am new to larger boats, (day sailor) and are unfamiliar with the current boat I am about to launch and step. Do I need a boot at the end of my spreader poles to hold the wire into place? Or does tension hold the wires in their grove? Any help appreciated, thank you.
Steve O.
tension or u-bolts
boots are only to reduce chafe on the sails.
Mar 18, 2005
84
- - Panama City, FL
Spreaders
You will probably find a hole through each spreader just inboard of the the shroud, which will allow you to wire the shroud to the spreader.
Jun 4, 2004
133
- - Plymouth
Seizing wire
Yes, I was told by the marina when stepping the mast that you must wire the spreader poles over the stays with stainless steel seizing wire just in case the stays "pop-out".
