spreader end replacement '85 Sirius 21
5
Vandestadt and McGruer 21 Traverse City
The polymer end of my 1" round aluminum spreader has broken. I would epoxy it but have not had great success glueing nylon-like plastics. Are replacements still available, any more common boats that used the same part? I can't seem to find any on the internet. We've had her since new with few issues.
Thanks for any help.
Harry
Jun 9, 2008
1,801
- -- -Bayfield
Can you take a picture of the good/other side - spreader and end so we can see what you are trying to match?
Sep 21, 2012
5
Thanks for your quick responses Tom & Bill.
Here's a shot of the broken spreader cap. As you can see part of it is still inside the spreader. Because the Sirius is a trailerable it is important that the new cap also be able to capture the stay so that it remains with the spreader & slides on the stay as the mast is lowered & raised. This must have been an off-the-shelf part in the summer of '85. There may be other boats with more production volume than the Sirius that are still be making parts available now.
Thanks, Harry
397
Macgregor M25 trailer
Whatt is the spreader id? The pics look like the same as on my m25, if the id is the same I have a couple of extra and could send you one.
Fred Villiard
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
Spreader Tip
I found this at (bwyachats) as it looks similar to yours it may work for you. I had been looking for one myself but couldn't find it using 'spreader' or 'end' or 'clamp' as part of its expected name. So far I have not reverted to "thingy" but I seem to be getting closer as time goes on.
Rigging 3204-110 SPREADER TIP, METAL--THIS IS A DIRECT REPLACEMENT FOR NEWER BOATS WITH ALUMINUM SPREADER TIPS AND AN UPGRADE FOR OLDER BOATS WITH THE EASILY DAMAGED PLASTIC TIPS. COMES WITH INSTRUCTIONS FOR RETROFITTING OLDER BOATS.
Kit Contents: SPREADER TIP WITH 10-32 X 1 1/4" ATTACHMENT BOLT AND NYLOCK NUT.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
Yep that looks like what I need two. The alternative is the whole spreader..
3201-1V0
SPREADER WITH TIP, 36 INCH
Notes: FITS ALL BOATS BEFORE 1995 26X EXCEPT V21 & V17.
-na -NA Anywhere USA
just a thought. Look at Dwyer Mast site as that might be the builder of your mast and spreader by chance. They are on line.
dave condon
Sep 21, 2012
5
Thanks everyone! I've bitten the bullet & epoxied the pieces together--it can be reversed if I find a part. I'm going to try it in the spring to see if it holds up.
Fred, that's a very generous offer; the ID is ~15/16". I'm going to stop at some boat yards that sell/service MacGregors in larger coastal cities in my travels this winter.
BTW, I've just had 2 new aluminum rudder stock plates fabricated--the ones that capture the kick up rudder. The others were worn badly by rubbing on the P. mahogany rudder over the years. I have Truant on a mooring in water so shallow that I have keep it kicked-up as it's too heavy to ship & unship each time I sail. The lake (Michigan) level is lower than it's ever been since recordings began!
Thanks, Harry
Dec 28, 2009
397
Harry, if you pm me with your shipping address I' send you two anodized aluminum ones that should fit.
Fred Villiard
