Spreader Boots
Catalina 30 TX
I recently purchased a 1985 Catalina 30. Should spreader boots be installed, or are the curved ends of the spreaders suficient to minimize interference with the foresail?
May 23, 2004
3,319
I would put a set on there, especially if you have a 150 and/or roller furling. That area will wear on a jib every time you tack, etc.
Joe
Jun 1, 2004
8,258
Can't do any harm... if it bugs you do climb up the rigging... you might consider gluing on some reinforcement patches where the sail rubs the spreader ends....Or....... do both..... if you're using a 120% or smaller sail it may not even touch the spreaders.
Jul 1, 2004
398
Catalina 30 Atlanta GA
spreader boots......a must to avoid chaffing. While your up there, check, clean and/or replace bulb in steaming light (deck light), check spreader hardware attachment to mast.
I think a sailboat looks naked without spreader boots!
Bob
'88 Mark II
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
Be careful to chose them wisely though because if they are sticky at all your jib may get caught up as you tack and it's a nightmare! Happen to us for quite some time on the boat we crew on... Finally one of our crew went up the mast and taped off the sticking rubber. Took a lot of effort and some scary moments in races when we could not get the sail around?
