Spreader boots for Hunter 335
Sep 8, 2009
19
Hunter 335 Lake Guntersville
Does anyone know what size spreader boots I need for a 1989 Hunter 335? West Marine sells three sizes (S,M,L).
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Same question came up on this thread and they purchased a large one: spreader boot size | Sailboat Owners Forums
My best advise is the climb the mast and remove the one you want to replace OR, if there is none then measure the spreader insert dimensions where the boot is going to be installed.
DArcy
Feb 11, 2017
1,770
Islander Freeport 36 Ottawa
I just replaced mine this spring. I measured the spreader diameter then walked into the store with a tape measure. They had the size I needed and they fit just right. My mast was down which makes all this very easy.
