Spreader base replacement
3
- - capecod
Dear O'day sailors, I purchased a 1986 O'Day 272 after having it surveyed and having a compresion test of the Westerbeke diesel. The surveyor missed the fact that one of the spreader bases was cracked. I would like to replace it but cannot locate a supplier. It appears to be a Z-spar spreader base P/N Z1025Q. I do not know what the mast style is However I have taken photos of all and will share them with any one who may have a solution. Does anyone have some thoughts on locating a base. Thanks for any assistance. Walt
Feb 7, 2007
3
- - capecod
wanted to write and let you all know that I solved the problem and located the spreader base. The people at US Spars had the parts. Very helpful and quick to respond. Those of you with O'Day 272s equipt with Z spar masts and booms should make a note of this supplier.
