Hi everyone.
I have a 1987 O'Day 272 LE with, I believe, a Z60 spreader bar set. I noticed that one of the rivets has pulled itself out of the mast and many of the other rivets have come loose on both sides. I am pondering on the correct method to repair this problem. I am looking for a permanent, best practices solution baring replacing a mast. There is minimal corrosion if any, and the hole is slightly enlarged where the rivet pulled out.
I have some experience with metal work and other related fields, but that is no replacement for the wealth of experience that I hope to tap into on this forum. I can post pictures if they are necessary.
