Spray Hood H31
47
Just wondering if anyone has removed the spray hood on the 31. Is it a big deal to remove and reinstall?
Dec 2, 1999
15,184
Not easy.
It is not an easy job. Why do you need to remove it anyway? If you go ahead with your plan. Be sure to put some type of rubber/plastic blocks on the tracks for the companionway slider. This will prevent water from getting under the hood and leaking into the boat.
