Spongy deck repair
WeiWei
Oct 26, 2015
6
O'Day 20 Keuka Lake
Anyone have information or links on injecting epoxy between the deck sandwich construction for repair of saggy spongy decks? I know the correct way would be opening the deck up and replacing core but looking for a quicker ,cheaper ,less work option.
Sep 23, 2009
1,480
Good chance you can find it on YouTube. West epoxy systems has some great booklets on this. I used it on a dry rudder with a smalll delamintion area. Be careful that the areas around your chain plates are dry and solid lest you end up with a corrosion failure.
WeiWei
Oct 26, 2015
6
O'Day 20 Keuka Lake
Thanks for the heads up. Those deck areas seem ok but now I realize I will have check hardware before launching.. The spongy part is
