Is this gelcoat or wood?...
and if gelcoat do you know if the fiberglass is cored over balsa or foam?The right answer will depend on this. However, in general if you have a void in there you need to fill with epoxy, failing a complete redo. You can see some of this on Fiberglass trilogy #3 above.ThanksJim Willis
