P.J. Longwell
Recently I discovered a vertical crack at the base of my mast approximately 1.5mm wide by 15mm long. The crack is along the forward seam, right at the apex of this "delta" shaped mast. There is a short post on the step plate just behind this crack. I am concerned that the internal lines that exit the base of the mast by turning on the internal blocks are exerting a lateral force on the base of the mast. I suspect that this pulling back on the base of the mast against the forward post of the step plate caused the crack.Team Catalina sent a patch kit. After drilling a hole at the end of the crack to prevent further spitting, an aluminum plate 1/4"x2"x2" was secured over the crack with 3M 5200 and 4 stainless steel self tapping screws.Needless to say I am concerned about the patch, and believe the split mast may reflect an underlying design problem. At least I don't have to look at the crack anymore!I would appreciate any information regarding this type of problem. Also an inspection of the base of your mast may be in order as the crack was rather subtle.
