I have a new to me 25 oday. I have a spinnaker, which is labeled head, tack and clew. I just pulled it out over my backyard and it sure looks like it is symmetrical...a perfect triangle. Should I measure it w/tape measure or is it obvious, and just labelled incorrectly? I also have two bails on the mast, one at the very top and one three feet down from the top. The po had a halyard going through a block at the lower one, he said he never used the spin, so I am a little bit lost here. My thought is to put my new halyard at the top and then get a nylon balls with a cable through them to mount the bottom of the spinnaker to go around the furled up genoa. then run a sheet through an existing block down on the forstays chainplate, to keep it pulled down and not ride up the furled up genoa, back to the cockpit? I think it will work if I do indeed have a asym. what do you think?
