Spinnaker Car P/N For H33.5
Nov 15, 2010
13
Hunter 33.5 Ladysmith
Hi
I'm looking for the part # for the spinnaker car,which is fitted to the Dovetail like slot on the forward side of the mast on my 1993 Hunter 33.5. The mast has a ID tag of Z-Diffusion Type H-33 RAK
Ref H-33 TALL.
Thanks
Rick D
Jun 14, 2008
7,208
I had a similar question for my 40.5. I was told that it is a Z-Spar section. While not currently imported, you can likely find what you need at Rigrite. I think it's necessary to unstep the mast in order to install it. I have seen several where the rigger simply put a track on. Good luck! http://www.rigrite.com/
Nov 15, 2010
13
Many newer Z-Spar Mast Sections feature an Internal Track Receiver Slot(s) extruded into the forward side. A variety of special Add-on (Insert) Tracks (25mmor32mm wide) are designed to fit in these Slots, for use with low-friction Slide Rod or Ball-Bearing Cars. Normally a factory-installed option,
This was copied from Rig Rite.On my particular there is a cover plate on the slot.I'm hopeful this can be used to install the car.
Thanks Rick
