Spinnaker Blocks for O'day 34
P
Paul R
Can anyone advise the best place to put spinnaker blocks for an O'Day 34. I have had the halyard installed but am not sure where to place the fair lead or turning block for the spinnaker sheets. My boat is a 1983 O'day 34 Thank You
Harlan
Jun 4, 2004
99
Oday 34 Niantic
spin sheet blocks
I put pad eyes on the small flat deck section that is just aft of the fuel fill and then use a snatch block in the eye if using a spinnaker. I also cut out about 4' of the teak toe rail cap midships and replaced it with T track, again with a snatch block, for the guy.
P
Paul Rybczynski
Good Idea
Vic I like this idea. It leverages a device already installed, no drilling, bolting, adding backing plates etc. Have you done this? What gear did you use? If you already have it figured out I could replicate what you have done and save myself time, heartache and probably some money because I won't have to experiment with different equipment. Thank You PR
